Removing Single Panel Fitting From Manufacturing Method/Sub Method|Forum|WOOD DESIGNER
OfflineHello Salman,
I have located the holes, they are being applied as a structure in your sub-method for the Material Styles.
See a greater explanation in the following video:
Can you please send me a copy of a cabinet containing a drawer with this problem?
I will look to find why this is happening for you.
OfflineI’m getting two unwanted holes on both edges of my drawer backs. I’ve reviewed all the sub-methods in the manufacturing method but haven’t found a way to remove them. Currently, I’m forced to delete them manually from the single panel fittings applied to all drawer backs. How can I properly adjust the manufacturing method to prevent these holes from being generated in the first place?![]()
