Request for cut list and plans processing|Forum|WOOD DESIGNER
April 17, 2019 - 5:26 am
Hi Arkadiusz,
You are right, it would be better to have an angle parameter that we could apply separately  to each joint.
I will certainly make this suggestion to the developer team.
Thanks for this feed back.
April 13, 2019 - 2:28 pm
Thank you Ness for the files.
It looks like within one project, a mitre-joint fittings can be of a one kind only… subject to system preference settings 🙁
If I may suggest future development feature: white defining tooling within fittings, the drilling type could have an angle parameter. Of course in most of the cases it would be set to 90 deg, however with some fancy designs it could very useful, e.g fitting horizontal shelf to a sloped side with a cam connector. Now it ends up with a solution like this:
snapshot.pngImage Enlarger
unless there is some work around I am not familiar with…
with regards,
Arkadiusz
April 12, 2019 - 3:51 pm
Hi Arkadiu,
Sorry I had forgotten that you had asked this and as this parameter is not saved in the model but in the general Polyboard setup, my Polyboard was not set correctly.
I attach the re-processed  files .
Have a great week-end,
April 12, 2019 - 9:29 am
Thank you Ness for your swift answer.
There is one question though. The fittings between Top&Sides of mitre-joint are not paralel to the side face but are perpendicular to the edge. If you recall I asked in a different post how to change that: https://wooddesigner.org/forum…..-hardware/
which I did. See the attached shapshots for details.snapshot1.pngImage Enlarger
snapshot2.pngImage Enlarger
Can production files be modified to reflect that?
Thank you
Arkadiusz
April 12, 2019 - 8:44 am
Hi Arkadiusz,
Sorry for the delay, but with some of our team away for the last week we have been a bit behind in processing files.
So with our excuses, I attach your manufacturing files.
Please excuse us for any inconvenience caused.
April 12, 2019 - 7:59 am
Hi Wooddesigners
Its been almost a week and I still have not received my production files. Is there a problem with my drawings?
surprised
April 5, 2019 - 7:22 am
ups…
here you go.
April 5, 2019 - 6:03 am
Hi Arkadiu,
I’m sorry but I can’t see you file.
Can you upload it again, and don’t forget that after you drag it into the upload window you must then click the “Add Files” button.
April 3, 2019 - 11:46 am
Good Day!
Please, provide production files for the attached project.
This is my first project ever so any feedback would be welcomed.
Thank you.
Guest(s) 42
everslyjoinery
Members: 537
