Tipon for double doors|Forum|WOOD DESIGNER
Forum Posts: 1663
September 5, 2025 - 10:51 am
Girts,
This is not possible to currently add this type of fitting for double doors in sub-methods.
I recommend manually adding these in single panel fittings.
This is a point that we are discussing and plan to bring up with the development team in the future.
Girts Martinsons
Forum Posts: 35
September 5, 2025 - 8:58 am
Take a look.
Thanks.
Forum Posts: 1663
September 5, 2025 - 8:30 am
Hello Girts,
Can you please send me a copy of a cabinet containing this method for me to look at?
I will then be able to give you some more information.
Girts Martinsons
Forum Posts: 35
September 4, 2025 - 5:29 pm
tell me please – why it’s not possible to create fitting link in manufacturing method – for double doors & tipon ?
i created tipon holes – with +50 and -50 from center, created fitting link – that double door is overpassing, and tipon has to be grooved in Upper or bottom panel – and rule I choosed Unique – Center Under passing panel – but when i choose the door – unfortunately it does not appear – but when i make it manually, through cabinet (right side where manually fittings and rules can be added) it does appear?
thanks.
Guest(s) 17
Topics: 3003
