Cabinet File Request|Forum|WOOD DESIGNER
July 18, 2019 - 5:53 am
Hi Justin,
Here are your files in inches.
best regards,
July 16, 2019 - 11:36 am
Can you resend it in standard instead of metric?
July 16, 2019 - 8:06 am
Hello Justin,
Here are you manufacturing files.
July 15, 2019 - 1:27 pm
Thank you.  I am ready to build it!  I am using this as a trial run to see if the program is something that I can use for furniture projects and cabinets in the future.  So far I have been pleased.  I want to see how the cut list and manufacturing documents go.  I appreciate all your help.
Forum Posts: 990
July 15, 2019 - 5:40 am
Hi Justin,
The back is still not closing on the sides.
back.jpgImage Enlarger
I added the corrected version. If it is OK let us know. A colleague will then be able to provide you the documents.
July 15, 2019 - 2:07 am
I think I have it put together now. What are the dimensions in standard for the face frames?  In the library it is all in metric.  Most boards dressed here come in standard.
Forum Posts: 990
July 14, 2019 - 8:59 pm
Hi Justin,
You can select the sides and in the links you select the back . If you add an overlap your back will be more inside the cabinet .
The other workaround for the faceframes is selecting the back and in the links you take the sides. Set the type to groove and add until the back connects with the sides. I saw that if you add 46mm on each side it will groove in the back 5mm on each side.back-extension.jpgImage Enlarger
There is no pocket hole assembly but there are special jigs for pocket hole assembly. Kreg is a known system for that.
July 14, 2019 - 8:00 pm
Here is the file with drawer revisions and vertical separator revisions.  When I applied face frames from the library it made the back panel come away from them.  Not sure how to fix that.  I followed your instructions and got the drawers and the separator fixed.  This is a bathroom vanity that will have a live edge slab on top and a bowl that sits on top of it.  I will also add feet to it which will raise it up off of the floor.  The drawers not being full depth are to accommodate plumbing.  I don’t want to do face frames for the back panel because it will be against the wall.  How do I make the back panel fit and close in?  Thanks.  Also is there an assembly method that uses pocket holes?
July 14, 2019 - 7:45 pm
How do I get that panel to snap to the edges?
July 14, 2019 - 7:25 pm
No I want it to close.  I will work on the file some more and then send it again for cutlist.  I appreciate your help.
Currently Online: Isaac
Guest(s) 24
Patrick Maylor: 60
Topics: 2099
Members: 260
