changing materials|Forum|WOOD DESIGNER
Hi Ian,
You have to set this material as your default material in the default manufacturing method.
To do this, you must set up the correct materials sub-method, add this to a manufacturing method and choose this method when you start your project.
The easiest would be to show you how to do this in a quick Team Viewer session.
Tell me when you would be free and we’ll set up a meeting.
cheers,
hi ,I know its a simple one but just wondering how do I change materials that I’m working with…. I have gone to material library and set up a material which I will be using , chipboard 18mm , but when I go to make a unit it keeps reverting back to a 19mm material each time.. so obviously my measurements will not be adding up… any help would be great with this..??
