August 23, 2016
Hi Marcelo.
Thanks for your information about the file not opening in Polyboard, we will fix it.
For assistance in using Polyboard please use the Technical Support Forum.
You have to sign up for Premium Support to access this forum.
Premium Support includes:
- expert technical help on the forum
- custom videos and models created just for you
- mini screen sharing TeamViewer sessions if required but you must first ask on the forum
- access to all training resources including our Quick Design Libraries
- on demand hardware set up service
- furniture and stair cut list and plans processing service
July 9, 2018
I am testing functionalities in polyboard 7 and it happens that when applying casing to a cabinet, with left side as main panel and front as secondary panel, after placing the casing we place a shelf with ceiling distance equal to 0, this shelf we make it a priority with respect to the casing and that's where the casing gets an inverted miter peak, I suppose that when working this error would produce incorrect panels.
Another detail that I found is that by opening one by one the models of the fast design library, specifically the model 'metal-wood-dining-room' the program does not open this file, perhaps due to another error or new feature, I downloaded it again but still not open the file.
I tried uploading the images and I could not
