Export ascii|Forum|WOOD DESIGNER
Export ascii
Forum Posts: 1748
September 23, 2022 - 7:50 am
From menu Cutting list > Cutting list options
mat.jpgImage Enlarger
You can select the option you need.
See attached screen shot, now if I export that gives me 3 columns,
imp.jpgImage Enlarger
Materials + thickness, materials only, thickness of materials only.
For more help, please subscribe to Premium support
All the best, Alexandre
September 14, 2022 - 2:58 pm
Ascii.jpgImage Enlarger
I want to export the list of only one type of material, to separate the materials.
I save them in csv from where I import them into excel so I can place an order with the supplier. If I have several types of materials and I have to order from different suppliers, I have to delete them from the excel list.
Forum Posts: 1748
September 14, 2022 - 10:31 am
Can you send me an example of the files you need?
September 12, 2022 - 10:34 am
Hello!
How can I export in ascii format only different materials?
In a cabinet, I use 8mm thick material for the back part and the rest of the parts are 18mm thick, how can I export them in different lists to be able to process them on the CNC.
Thanks in advance!
Guest(s) 36
Duayne Naugle: 129
Patrick Maylor: 60
dziekan
AKM
Topics: 2095
Members: 258
