Hi Behnam,
Mitres have main and secondary panels that can be selected in the Links menu.
Aligning drillings on the drawer sides and cabinet sides is explained in the drawer slider video here:the forum.
https://wooddesigner.org/suppo.....libraries/
Your questions are technical questions that should be posted in the "Polyboard" section of the forum.
Please consider signing up for Premium Support this will give you full access the forum, videos and mini Team Viewer sessions where we can help you with all your technical questions.
best regards,
July 26, 2017
Dear All,
We have some problems in using fitting systems.
In using Mitre-Joint connection, we can not define any fitting because program don't detect overpassing and underpassing correctly. Please check attached picture, I show the problem with black arrows.
Another problem is when we want to add drawer and use railing systems. We should add some drilling points on the sides of drawer and also sides of the cabinet. About adding holes to the sides of drawers there is no problem but about adding holes to the sides of the main cabinet right opposite of the holes on the sides of the drawer we have problem and we can add them at the correct place.
Please help us to solve these problems.
Best Regards
