Install problem|Forum|WOOD DESIGNER
Install problem
May 20, 2021 - 10:11 am
In the command line:
PC\Desktop\polyboard-lib-v7.1\setup\polyboard7-lib.reg
the folder in bold and under lined does not actually exist.
I went directly to the setup folder and double clicked the polyboard7-lib.reg file and it did what I assume it was meant to.
laughlaughlaugh
Forum Posts: 990
May 20, 2021 - 9:56 am
Hi Andrew,
Can you tell which path was the issue for you?
May 19, 2021 - 10:04 pm
Hi Michel
I have solved the problem. There is a folder in the command path which doesn’t exist. I found the regedit file in the setup and ran it. It seems to have worked. Time will tell.
May 19, 2021 - 5:13 pm
Hi Michel
These are the errorsUntitled-1.jpgImage Enlarger
Untitled2-1.jpgImage Enlarger
Untitled3-1.jpgImage Enlarger
Untitled4-1.jpgImage Enlarger
Forum Posts: 990
May 19, 2021 - 4:29 pm
Hi Andrew
these are not errors. The file needs to register in your registry and you should accept it. Unless you get another message. If so please add a screenshot of it. We need to see the problem
May 19, 2021 - 4:17 pm
I can’t get off the ground with this. When the end of the libraries install happens I get 2 errors to do with updating the registry. Then when I open the program there are no design tool bars. Any idea what may be the problem?
Guest(s) 14
Patrick Maylor: 62
Topics: 2102
Members: 260
