Complete PDF cutting list, dimensioned PDF drawings and DXF files of all the separately cut parts.|Forum|WOOD DESIGNER
Please find attached the 3DS files for the two projects, which can be imported into SketchUp to obtain all the dimensions required.
Isaac said
Hi Bart,
1. If you provide me with your project file, I can give you manufacturing documents such as the CSV cutting list, PDF documents, and dxf files.
2. I can provide the CSV cutting information for each panel with all of the required information except for the drillings. This will need to be referenced on the PDF documents.
3. See the following link, this will show you how to add hardware to cabinets:
Feel free to send me your file and I will provide you with the documentation.
Hi Isaac. Here i am again. The compagnie would need the exact location in the drawings were the ‘drevels’ the holes for connecting both sides of a cupboard.
They need the exact higth. Can i put them in with polyboard so that i have alo every hight measure ther were they need to drill? So the holes for every fix panel. i v seen this video and i understand there is a screen leftunder with ‘reference axes’ witch does’ntappear with me.
I hopemy question is clear. Thx, Bart
And/or, is’nt there a file format that can be used in Sketchup? Got it once from you guys when i was buildiing two staircases.
And if i can sort it out with polyboard i will nee the new extracted DXFfiles
Isaac said
Hi Bart,
OfflineIsaac said
Hi Bart,1. If you provide me with your project file, I can give you manufacturing documents such as the CSV cutting list, PDF documents, and dxf files.
OfflineHi Bart,
See your files attached.
OfflineIsaac said
Hi Bart,Please view the following:
Hi. Can i receive files so that i can show them to client this weekend. I will adapt manually in sawing list the doors, should there be a problem.. now son s here and i can t continue anymore this eve. Thx and have a good weekend! bart
OfflineHi Bart,
