Complete PDF cutting list, dimensioned PDF drawings and DXF files of all the separately cut parts.|Page 3|Forum|WOOD DESIGNER
Bart Van Hoorebeck
Forum Posts: 62
May 15, 2025 - 10:11 am
Hi Isaac!
The question actually wass as posed. Ther is something not correct in the panel measuring. IN the other projects it is correct. On the right  wing ‘living’ , the progrm measurin is not correct. Can you look into the problem?
As it is now, my project wil be to big.
When do i receive my files?
Thx and Kind regards, Bart
Forum Posts: 1441
sp_UserOnlineSmall Online
May 15, 2025 - 9:48 am
Hi Bart,
Thanks for following up — I just saw your email and I’m very sorry for the delayed response. I accidentally closed the conversation on my end! I usually aim to reply the same day to all questions.
You’ve done the right thing by setting up the panels in Project Mode. This approach makes it easier to edit them independently of the cabinet, which is ideal in this case. Just confirm that everything you have will fit in the length of your project space in real life, especially in the Project Living model.
As for the hinge allowance, that’s quite standard. Just double-check it against the technical sheet for the specific hinge you’re using to be sure.
Your customer can download the demonstration version, view these projects, and even take measurements. There are no design limitations in the demo version, so it’s a great tool for communication between you and your customers.
Again, apologies for the late reply. Have a great day!
Bart Van Hoorebeck
Forum Posts: 62
May 11, 2025 - 8:58 pm
Hi Isaac.
I Updated/finalised my project.
Still some questions: In Project living you see measuring that measures a cupboard (r) with thickness sidepanel and otherwise  (left one for example) it sexcluded. Tough, When i open the right cupboard, the with i get is the same as in the projectmodus, but clearely without the right panel (that is created in the projectmodus)
I ve taken the with off my door with a play off 3mm in between doors. At the hingeside i have taken 2.5MM. Is that enough you think?
In this case, the clinet is IT . So i was thinking, they were asking,. to download the free version from you guys . So they can easily look into the projects.
Can they see measuring?
In attachement the projects.
Thx in advance.
Bart
Forum Posts: 1441
May 8, 2025 - 9:10 am
Hello Bart,
See your files attached. Please review them before manufacture.
Bart Van Hoorebeck
Forum Posts: 62
May 7, 2025 - 1:00 pm
Ok, thank you Isaac.
Attached one file off witch a m pretty sore that its correct. I’m waiting with hardware cuz when a adapt in pdf it will be no issue.
Thk you very much! Bart ((its getting better all the time ;))
Forum Posts: 1441
May 7, 2025 - 10:19 am
Hi Bart,
1. If you provide me with your project file, I can give you manufacturing documents such as the CSV cutting list, PDF documents, and dxf files.
2. I can provide the CSV cutting information for each panel with all of the required information except for the drillings. This will need to be referenced on the PDF documents.
3. See the following link, this will show you how to add hardware to cabinets:
https://wooddesigner.org/help-…..-hardware/
Feel free to send me your file and I will provide you with the documentation.
Bart Van Hoorebeck
Forum Posts: 62
May 7, 2025 - 9:35 am
HI Isaac,
So now i m practically finishing the project and back from the customer
Three points:
I can’t seem tot send the (adapted) project to customer. Option printer PDF file are not to use for me as i am working in yearly rented version. Solution?
To answer your question: what i need is an excell file as in attachement.+/- What they need to know is the size of every panel, (not massive panels ) Holes for blum inserta, wHat to chamfer, holes for every connection (drevel or in english ‘drift’?) 8MM
I ve looked to insert in my drawings all the holes with libary. don’t now what to choose and how to put them in. Is ther a tutorial?  (maybe not neccessary. Depends a bit from the excell file that you sent me)
Is it possible that you evaluate my project, since it s my first one?
Kind regards, Bart
Forum Posts: 1441
April 29, 2025 - 10:21 am
Yes, I can provide files in excel (CSV) automatically for you.
What format do you need (what information) for excel.
Bart Van Hoorebeck
Forum Posts: 62
April 29, 2025 - 10:14 am
Hi Iaac,
In fact i don’t think they offer the service currently. I’m listening now with another compagnie
They both have ‘ardi’ but i still need to input everything manually.
You can’t provide my cutting lists ‘automatically’ in excell? for example?
Or, you can give me factories working in Belgium with you re files?
Kind regards, Bart
Forum Posts: 1441
April 29, 2025 - 9:36 am
Hello Bart,
With the CabinetFile service we do provide a CSV output. I will also provide a CSV template showcasing the format.
If there is a more specific format you require, you can send it to me and I will analyse it and notify you if it can be provided.
Currently Online: Isaac
Guest(s) 52
Timothy Bennett
Members: 536
