How to Import DXF in Optinest and generate output for labelling and Nesting DXF. |Forum|WOOD DESIGNER
Forum Posts: 2110
September 21, 2023 - 3:21 pm
You just Need to Add text to work but some files you joined already have text entities with Hor. drilling Bloc.
May be more easy with files names
James Singh
Forum Posts: 14
September 21, 2023 - 2:07 pm
Hi Alex,
Thanks for the info.
Can you please guide me to read TEXT entities in DXF file and have them printed in the label?
For e.g., I want to place the Project Name as a TEXT in the DXF and have it printed.
Many Thanks,
Ash
Forum Posts: 2110
September 20, 2023 - 3:43 pm
Grain values are ,
Grain = “0” or default :  All rotations.
Grain = “1” :  No rotation.
Grain = “2” :  90° rotations only.
Please find sample can be imported with option Rectangulare parts import
Layers names is for setup outline layer part in DXF Output
Reference is the part name
Thickness of panel but no impact on import
James Singh
Forum Posts: 14
September 20, 2023 - 2:57 pm
Hi Alex,
I just have few questions here
1. What is Reference?
2. What should be in the Grain field? Grain direction or to say Grain is present or not? i.e. Should the field hold, “Horizontal”/”Vertical/No Grain” or “true”/”false”
3. Layer name for what?
can you please make one sample file to understand, the fills.
Many Thanks, Ash
Forum Posts: 2110
September 20, 2023 - 2:38 pm
CSV is limited and can you be used for rectangulare part without extra machining
CSV import format in OptiNest is:
    Height;Width;Quantity;Reference;Grain;Layer Name;Thickness
(EDIT : Reference, Grain, Layer Name and Thickness information are optional)
James Singh
Forum Posts: 14
September 20, 2023 - 2:04 pm
Thanks for your help, it seems complicated is their way than I can import CSV file here, this can work for me. I have shared CSV with you.
Thanks, Ash
Forum Posts: 2110
September 20, 2023 - 1:50 pm
Hi!
Of course! But
From PolyBoard to OptiNest, Layers are setup per operation
Looking at the files you’ve attached, it’s not a problem, the DXFs seem to be clear,
From OptiNest, you need to create new outline layers. Here, it’s ProcPart_18 (for depth?!) but replace 18 with “*” for character groups.
– in the case of multiple contours, separate each new layer with “;”.
– Horizontal holes are a Block, with layer 0, but you may need to exclude this layer “0” or “H_drill*” with a slash in front of /H_drill*
then create a new path with the name of these new layers in Vcarve
Hope that’s helpful, Alex
James Singh
Forum Posts: 14
September 20, 2023 - 11:18 am
Hi Alex,
Some of our Interior Designer, who is working on different software, get DXF output, can we use these files to generate a Nesting DXF file and Labels as well in the optinest?
Thanks,, Ash
Guest(s) 154
Emmanuel Sacco: 176
Zaheer Abbas: 173
Tom Jackson: 124
Mounib osman
Sebastian M.
Tom McGranaghan
Mohamed Mekayed
Juan Carlos Izquierdo Hdez
Taras Orlyk
Jacob McKay
Juho Simuna
Nahuel Sena
Björn S
Topics: 2849
Members: 516
