Labels don't match the cutting plan|Forum|WOOD DESIGNER
Forum Posts: 2128
May 24, 2023 - 3:13 pm
As I said in my previous message, this is not a bug, and this principle has not been changed since the previous versions
Tom Cleaver
Forum Posts: 166
May 24, 2023 - 1:32 pm
Hi Alex,
Any news on this issue?
I am using version 6.04f. I recently updated the toolbars and libraries for polyboard.
Kind regards
Tom
Forum Posts: 2128
May 19, 2023 - 2:05 pm
Quick check it is already the case from OC5 no change hase been done for many years on this subject
OC5.pngImage Enlarger
Forum Posts: 2128
May 19, 2023 - 12:14 pm
Hi noted,
I’ll ask to developpement team’s more information and come back as soon as I have replies
Tom Cleaver
Forum Posts: 166
May 19, 2023 - 11:15 am
Hi Alex,
I’m not sure I understand. The example you have sent through still shows the label with the length and width dimensions swapped from the cutting list. We have always read a dimension from the cutting list as length (grain) then width.
Also displaying dimensions laterally on the cutting plan makes no difference to how the labels come out. The cutting list is not the problem, it is correct whether the dims are displayed centrally or laterally. It’s the fact that the label/ s don’t match the orientation of the cutting plan.
We have used Opticut and Polyboard like this for a few years now and this is the first time the label did not match the cutting plan?
Am I missing something?
Kind regards
Tom
Forum Posts: 2128
May 19, 2023 - 7:55 am
This happens on the piece that has received a rotation
rot1.pngImage Enlarger
The labels show the height and width of the part
rot2.pngImage Enlarger
It must also be taken into account that the label will also be stuck with a rotation
labelsd.pngImage Enlarger
I prefer to display the size of the parts in the laterals
Hope that’s helpful, Alex
Tom Cleaver
Forum Posts: 166
May 18, 2023 - 2:34 pm
The dimensions of the piece on a few of the parts on the cutting list don’t match the labels. As in the length and width dims are swapped.
Any ideas?
2023-05-18_143057.jpgImage Enlarger
2023-05-18_142930a.jpgImage Enlarger
Currently Online: Fatima
Guest(s) 50
Pavel Kudrjavtsev
Javier Velázquez
Topics: 2933
Members: 555
