Manual Saw|Forum|WOOD DESIGNER
Manual Saw
Forum Posts: 2128
September 6, 2022 - 11:11 am
From OptiCut, you have several configurations according table saw
-You can force First Cut direction
FCD.pngImage Enlarger
-You can set the maximum cutting level to limit the rotation of the parts.
MRL.pngImage Enlarger
-Or sort strips
Sort.pngImage Enlarger
Attached is the same cutting plan as the one sent earlier, but with these options, manual sawing should be easier.
Ahmed Naeem
Forum Posts: 14
September 5, 2022 - 1:37 pm
Hi
What we are trying to do is switch the opticut cutting method to a sliding table saw . We are using a sliding table saw to cut our plywood boards.
Forum Posts: 2128
September 5, 2022 - 7:43 am
For the manual saw, we recommend using your OptiCut
software with PolyBoard, which allows you to obtain a cutting plan in a few minutes and labels.
It perfectly manages the grain direction ( > Perfect grain), and stock.
Please find attache sample of your models “Kitchen” into QuickDesign libraries
adapt to the size of your company from 50 pieces to Unlimited pieces per Optimisation
50 for 2/3 cabinets, 200 for a project like this standard kitchen, 500 for grouping 2/3 projects (kitchen + dressing room), unlimited for series, and PROPP (unlimited ) for the compatible CNC saw.
Ahmed Naeem
Forum Posts: 14
September 4, 2022 - 9:08 am
Hi how should we proceed to optimize the cutting panels if we were to cut the panels manually?
Guest(s) 47
brendan kavanagh: 227
Emmanuel Sacco: 196
Carl O'Meara
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2906
Members: 540
