Multiple projects combined in Optinest 3|Forum|WOOD DESIGNER
Forum Posts: 2128
March 3, 2025 - 10:56 am
DXF import and PB export is not the same,
Better way for my is to copy and past parts from project to another
Another solution, now if you are well in PB 7.12D, you can edit our PP to export in ON3 format *.nst
ON3-format.pngImage Enlarger
and in this case when you export to another *.nst file you can combine them
add-or-replace.pngImage Enlarger
Hope that’s helpful, Alex
Forum Posts: 1444
March 3, 2025 - 9:28 am
Hi Mark,
That is correct for the time being, you will need to nest each separately for the moment to have those details. I am going to do some more research into this today to see if I have missed something in my understanding, or if there is something I can do so that you can nest them together.
mark nichols
Forum Posts: 165
March 3, 2025 - 9:13 am
Hi Issac
Thanks for that. The problem of labels detail that exists with a dxf import will be there though and the additional details that come in via the polyboard to optinest import will not show presumably
Mark
Forum Posts: 1444
March 3, 2025 - 8:05 am
Hi Mark,
mark nichols
Forum Posts: 165
February 28, 2025 - 6:13 pm
Hello All
Is it possible as in optinest 2 to export multiple projects of the same material and to be able to combine them into one nest in optinest 3.
My projects are coming in with their filename on the ‘tab’ and each project is seperate.
Am i missing something as in opti 2 all mdf 18 (as an example) came in under the same file, like filling a bucket with parts.
Mark
Guest(s) 38
everslyjoinery
Members: 537
