Nesting optimization not capturing all panels. |Forum|WOOD DESIGNER
OfflineHi Keith,
Find a video attached answering your latest question.
Let me know if there is anything else I can help with.
OfflineKeith,
This seems to be a problem, we are working on getting this rectified.
OfflineHi Keith,
I am looking into this now.
I will reply soon.
OfflineHi Again,
So just a quick update.
My material sheet size is 1220 x 2440. I had one component which was 600 x 2500 ( bigger than the sheet). Although all components were transferring into optinest good it would not optimise any of that size material that was the same as the oversized panel.
I would of thought it would of just left the over sized panel out as opposed to all components in that material description.
When I exported into optinest, I just deleted the larger panel prior to optimising and it worked for me then.
Should I have done something different ??
or
Am I missing a key setup or step in optinest ??
Thank you again.
OfflineHello Guys,
I have a unit Drawn and sent to optinest for outputting into Vcarve.
So I have done projects with all the materials involved before and managed ok. So they should be in my optinest library.
Problem is when I nest our optimise its not nesting all parts. for some reason. I see the individual components within the file when I save it I can also see them in the parts list but they wont optimise for some reason. Panels are in optinest and the qty is set to unlimited.
I have tried to attached the polyboard file for reference however its says its to large apolagies.
Thanks in advance
Keith.
