OptiNest Crashing Polyboard|Forum|WOOD DESIGNER
September 8, 2021 - 8:45 am
Hi Dave,
Our customer support is going to contact you. I think you do not need a new activation code as per your post it seems that your version 7.07A1 is activated.
About the library issue as you are located in New Zealand we need you to make yourself available according to our time ( France ) as the developers need to contact you via Anydesk to look at your issue. Please also arrange a timeframe with our customer support so that we can arrange this connection.
Blake Simpson
Forum Posts: 104
September 8, 2021 - 5:59 am
Hi Michel
thanks for sending through Version 7.07A1
this has fixed the optimise issue with missing the components however we still cannot redirect the Parameters-Library-Materials to our shared drive as Polyboard crashes while all fine with Method and Textures.
Also for some reason with OptiNest 2.31n printing the labels the clashed edges are now identified incorrectly with LH or RH edges around the wrong way. see attached label print out along with Polyboard unit.
Dave
Blake Simpson
Forum Posts: 104
September 7, 2021 - 9:37 pm
Hi Michel
Ok I have learnt my lesson on not to uninstall – yes I have an Uninstallation Code on my desktop (copy attached). Can you let me know what I do with this, hopefully it will allow me to get back up and running?
Also attached the screenshot for the error notification.
yes the issue is with top component – I’m not sure what you mean by On start correctly?
Dave
September 7, 2021 - 1:58 pm
Hi
This has been solved in a new version 7.07a1
Il will send it via wetransfer
September 7, 2021 - 9:17 am
Hi Dave,
Can you also confirm from your side if it is only the top that is missing and that ON start correctly? This is the outcome I have on my version. Developers are informed and I will revert shortly
September 7, 2021 - 8:14 am
There is a screenshot of the same type of error showing on our post.
September 7, 2021 - 8:01 am
Hi Dave
Also no attachment visible in your post
September 7, 2021 - 7:58 am
Hi Dave,
You should never delete a version like that. Have you checked your desktop as you should hopefully have got a uninstall code file on it upon removal. I got a reply from the developers. They want to get connected on your pc with Anydesk but it seems you have made it impossible now due to that action. Never try such things on your own without consulting us.
Check and confirm if you have the uninstall code generated on your desktop. How did you remove the software ?
Blake Simpson
Forum Posts: 104
September 7, 2021 - 4:28 am
Hi Michel
We have another issue for whatever reason when we optimise our existing library units not all components are optimised and get an error message (see attachment).
This has caused problems as we do not know what’s missing unless we go through optimised sheets comparing components to cultist.
I have now tried to reinstall old version 7.06f but had to delete beta version to do this but know my old activation code will not work.
this turning into a complete cluster #%&* as trying to get jobs out for production
Dave
Blake Simpson
Forum Posts: 104
September 5, 2021 - 10:07 pm
Thanks Michel
With the upgrades this seems to have fixed our issue, however with Polyboard 7.07a beta version we are unable to redirect [Tools-Folders-Parameters-Material] to our shared drive? we are able to link Method and Texture but when we select ‘Material’ Polyboard crashes
Dave
Guest(s) 50
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
