Part orientation|Forum|WOOD DESIGNER
Forum Posts: 1444
OfflineHi Scott,
No, there is currently no setting that will define which way a part needs to be assembled, or which goes toward the cabinet top.
The only work around I have come across for the moment that will highlight the top is by creating an edge tape that is 0mm thick. You could label this edge tape “top” and then the top of your backs will be highlighted. (this is only an option if you usually don’t edge the top of your back pieces in PolyBoard).
I have attached an image of this below, tested in OptiNest. NOTE: I have not changed the name of my edge tape for this test, I only used an edge tape called “Edge-040,0.0mm”.
Guest(s) 38
everslyjoinery
Members: 537
© Simple:Press —
