polyBoard to opti nest Glitch|Forum|WOOD DESIGNER
July 12, 2024 - 3:53 pm
Can you send you cabinet for analysis,
But first of all,
-without having your cabinet, are you sure that you can’t see the counter from top in the preview? In other words, if your panel has machining on both sides he should be flipped
If you select your part and click on DXF Tooling and you see F2 that would mean that your tooling is on the bottom of the part.
Parts with both side drilling/milling are assigned with properties “2”
F2-tooling.pngImage Enlarger
in case of both side milling/drilling, Right side of panel always on top!
>PolyBoard and OptiNest nested manufacturing with doubled sided machining and edge drilling
*If, when you import the part with the internal tooling, it looks like the second job on the screenshot below.
ON-import.pngImage Enlarger
I would say that the DXF layer import option is not properly configured.
ON-import-DXF.pngImage Enlarger
This setup is add if you install our QuickDesign libraries,
hope that’s helpful, Alex
Vicky Hope
Forum Posts: 7
July 12, 2024 - 2:16 pm
When nesting for a cabinet its not mirroring the sides instead it does same side twice so the tooling goes wrong
When Doing a Cabinet everything seems fine in polyboard then after nesting instead of doing a panel its creating a frame around it and leaving the center as a cut piece
Guest(s) 30
