2 way sloped cabinet |Forum|WOOD DESIGNER
OnlineHello Ben,
Sorry for the delayed response.
I believe that the best way to achieve this with a single cabinet is as seen below:
I will continue to test options and let you know if I find a better solution.
OnlineBen,
If you can upload the image of the room that will be helpful. Please compress the image (into a zip file) so that it will fit in the chat.
If that doesn’t work, you can compress it and upload it into the file uploader:
Offlinehi isaac, thanks for getting back to me i have sent the file for the angled corner unit i have popped a measure for the height of the wall to create the correct angle the problem i am having is i need the top back left point to angle down to the same height as on the right. when i do multiple slopes it only allows me the angle the top right side and drops it down from that point.
OnlineHello,
Hopefully I have understood your question correctly. Let me know if you have any further questions.
Offlinehi i have attached my project and also a picture of the area of the house so you understand what im trying to achieve. i understand how to make the slopes back to front and left to right but how come i cant do both on my unit without the unit going back to front just seems abit odd hopefully someone can help.
it wont let me upload the image of the room as its too big for it to process but essentially its a wardrobe in a new bungalow dorma extension to upstairs so the wardrobe is going into the corner where there is a slope along the back but also along the side.
