3 Door cabinet|Forum|WOOD DESIGNER
OfflineHi conor sorry for this..
I speak English like a Spanish cow…
and forget to send files ….
i edited the last post and made this video
I hope to be clearer this time
cheers, Alexandre
Offlinethere is no way that Polyboard does not change the position of the vertical division,
Polyboard automatically uses vertical division as a reference,
In the first file (simple equa) I just equalize the doors
in the second file (Lhsinner) I edit Slack doors with vertical division to change the position of the overlap and equalize the doors afters
hope that’s helpful
OfflineCan you post your cab please,
OfflineHi Alex, I just tried the equalize option on the doors which works for the doors but places the 19mm internal vertical division half way between the first and second door.
I would like to move the internal vertical division 9.5mm to the right so I can hang my second door on it.
When I change the internal size of the cabinet the doors automatically become unequal.
Is there a way to equalize the doors without changing the internal cabinet?
Thanks, Conor
