7.07hCrashing when opening |Forum|WOOD DESIGNER
December 11, 2021 - 4:18 pm
Hi Kjetil,
This is caused by the parameter you chose. ” positioning = distance from the drawer bottom”
This parameter is set in the bottom reference of the drawer box. The drawer bottom in PB is the lower part of the drawer front. This can be confusing sometimes.
The below image shows you this. So in this case when you put your drawer as applied you do not have sufficient space between the drawer box bottom and the cabinet volume
cabinet bottom panel is 16mm. When the front is applied you have a 1.5mm recess which results in a 14.5mm drawer face overlay. As you set the parameter to 14mm the box crashes into the cabinet volume. As a test, you can just change to 14.5mm and it will work but the box will be on top of the volume bottom which is something you do not want.
side-view-drawer-bottom.pngImage Enlarger
It is best to work with the parameter ( distance from the Bottom of the zone inside). This way the drawer box bottom will always look at the zone inside the cabinet and respect that distance. You avoid at all times crashing your drawer box into the volume bottom.
December 10, 2021 - 11:34 am
When i try to change the drawer to global it cannot calculate.
I can just draw drawer bult in like this cabinet. If i change this the drawer it will diseappear??
December 10, 2021 - 7:46 am
can you upload one cabinet with this problem
and give me more details
Best wishes, Alexandre
December 9, 2021 - 4:47 pm
Ther are still som problem with polyboard.
Now ther are iusus with calkulating the drawer i global
December 9, 2021 - 12:21 pm
alex.
do you sending me email? zoom ID
December 9, 2021 - 10:53 am
The program is still in demo mode and cannot read the license file, the program starting up when I change the library like you told me too but the problem now is that I need to activate Polyboard again
We can connect with zoom at 1315 today
December 9, 2021 - 10:38 am
hi, licence are ok?
well return to “An unexpected Error occurred upon loading Methods” ?
a can look between 13h15 to 14h15 (paris +gmt) by Zoom
But I, don’t speech Englishembarassed
December 9, 2021 - 9:52 am
Teams at 12 ?
December 8, 2021 - 9:08 pm
Did you delete or rename the folder?
If you only rename, just rename libs_old, to libs should resolved this.
If Polyboard return to “An unexpected Error occurred upon loading Methods” let me know when we can make screen sharing session
to make my best for don’t loose your work
All the best, Alexandre
December 8, 2021 - 3:19 pm
Yes, when i deleted the libe. The program started up again but it vil not read the lissens file.
Guest(s) 50
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
