Hi Connor,
Polyboard 7.06C is now available on the download page for this issue,
All the best, Alexandre
Hi Connor, I've emailed you a possible date for a screen share session to look at this slack issue. Thanks
February 22, 2021
The only solution I know of would be to use panels with a false thickness,
for example 12.5 mm instead of the classic 12 mm.
Cheers, Alexandre
February 22, 2021
February 22, 2021
For the hole near M&T created when changing priorities
February 22, 2021
For all your duplicates, you give two opposite pieces of information, which means that Polyboard cannot understand
If you change the priorities, you cannot add grooves too
But I see the anomalies, I'll report later to dev team regarding the M&T
Please see this video for full settings
February 22, 2021
Connor said
Thanks. I've come across a couple issues below if you can help please:
It won’t let me add slack to the groove panels at the front of my unit. I’ve added the measurements but it’s only applying to mortise/tenon shelves.
Also, the rear double backs are set to mortice/tenon but they are creating a hole below the cut out on the side panel. I know about the groove/oversizing settings, but that doesn't seem to get rid of it.
See attached updated file.
February 22, 2021
The front double backs are set to groove, but it doesn't appear to be cutting it out of the side panel on the 3D image. Am i missing something?
I hope this video's helpful
It's easier to add a square with inner tooling if you are novice in CAD drawing
Connor
February 22, 2021
That's fine, seeing how you did the main curve has helped a lot. Just struggling to add any extra's to it, such as the square cut-out. When i opened the editor it changed the curve entirley, as if i was starting from scratch.
How did you add the square cut-out after creating the curve?
I only have an old copy of the outline on dxf, you may need to remove the previous mortise-tenon cut outs.
I did it very roughly,
can you send me the real form of the side in dxf?
If you open the model, you can restore and see the curve I made
February 22, 2021
Closed curve should be use for cabinet view from top in free shape mode or inner tooling
May an open curve in angle tooling is more useful for your project
Please find cabinet Upload for example (In Polyboard 7.06a)
Hope that's helpful, Alexandre
