adding shelves to unit with vertical div|Forum|WOOD DESIGNER
brendan kavanagh
Forum Posts: 226
March 16, 2022 - 3:05 pm
Hi Alex
Thank you very much for your help its exactly what i want
Caroline
Forum Posts: 2128
March 16, 2022 - 2:11 pm
Here it is!
All the best, Alexandre
brendan kavanagh
Forum Posts: 226
March 16, 2022 - 1:36 pm
Hi Alex
Im sorry but can you put this on a video only new to inner tooling not sure how to
Thanks for your help
Caroline
Forum Posts: 2128
March 16, 2022 - 12:50 pm
First have inner tooling of 71mm x 20mm
and second 71mm x 392mm
edi3.pngImage Enlarger
brendan kavanagh
Forum Posts: 226
March 16, 2022 - 11:20 am
Hi Alex
Yes thats exactly but with the panel on the right hand side flush (double back as previous unit) , does that mean i have to set back the shelves to allow for this??
Hope this makes sense
Caroline
Forum Posts: 2128
March 15, 2022 - 4:01 pm
maybe like this?
ed.pngImage Enlarger
brendan kavanagh
Forum Posts: 226
March 15, 2022 - 3:43 pm
Hi Alex
Yes I can do a drawing no problem, but if you see the unit attached again just want to add the shelves top and bottom as the unit is
Thanks Caroline
Forum Posts: 2128
March 15, 2022 - 11:34 am
Can you make a quick drawing of what you need, to see how we can achieve it?
by hand or by screen capture edit with MS paint, save as png
brendan kavanagh
Forum Posts: 226
March 14, 2022 - 4:22 pm
Hi Alex
Yes i see how you did that but i want to keep the double back panel on the right hand side of the vertical (but not left of the vertical)  flush to the front and also the shelves to be flush to front which probably means a cut into the shelves to allow for the vertical
Does that make sense??
Caroline
Forum Posts: 2128
March 14, 2022 - 3:53 pm
it makes sense, if I understand correctly wink
You add recess on Vertical division from back but orignal panel already exist,
to overcome this constraint,
add a nil double-back at 70 mm from the front, add a vertical division in front of the nil double-back to have 70mm Vertical division, and add the shelves behind it
Currently Online: Nadeem Lotia, Isaac, LORIN STANCIU
Guest(s) 49
Timothy Bennett
Members: 536
