Adjust plints so they have same width as cupboard a o|Forum|WOOD DESIGNER
OfflineIsaac said
Hi Bart,See the following video for referencing textures:
Hi Isaac. So, i watched your video, but moved the polyboardmap into my documents because i tought it would work easier. Not! i ve lost everything in my library and when i upload, computer says noo. the progam indicates ‘fault’. An unexpected error… . So now i’m realy stuck. if it comes
to the textures.
OfflineHi Bart,
Do you have a copy of the file that you a referencing?
If you post it here, I could show you an example with this library.
OfflineAs a response to using the quick libaries:
I Watched the tut. See a whole range of oppertunities, but when i open my version and imittie what you are doing i don’t have the same (very little) oppurtunities. When i open Unilin zip file with my decor (received from unilin) and i do an upload i can’t integrate it into my cupboard. :/ . Same with a picture (jpg) from oaken. (so it appears in my library, but can’t use it)
Printscreen not allowed
Kind regards, Bart
Most of the details can be found in your video tutorials from the link below.
and
Offline
OfflineHi i m a New user polyboard 8. (premium for one year) I currently have two questions. one: Looking at a video to create a plint i encounter the following problem (see print) Will the same problem occur wel making a pacelat?
Two: I have to assemble my drawings in in a ‘project’ and copie them. Because i have to have more of the same tot create my cupboard. Howtot do that?
Three: I have to put decors (unilin) and oaken massive(what will be a self constructed panel) into my libary. How tot do that?
Anyone?
Thx in advance!
Sincerely Bart,
