AES cnc machine|Forum|WOOD DESIGNER
AES cnc machine
December 30, 2022 - 12:13 pm
Hi Zaheer,
Please read this topic on our website. There is an integration possibility with Alphacam.
https://wooddesigner.org/help-…..rdesigner/
Zaheer Abbas
Forum Posts: 154
December 30, 2022 - 10:09 am
Dear Michel
If i already have alphacam. But we need to use polyboard. Can we take from polyboard to alphacam then to machine?
December 30, 2022 - 9:37 am
Hi Zaheer,
It is impossible to go directly from Polyboard as your machine uses a direct gcode. Polyboard is not a cam software providing gcode. V-carve is a cam software in between that works perfectly with polyboard.
As you have a point-to-point CNC, I must inform you that this software does not allow horizontal drilling or machining. AES works mainly using Alphacam as a cam solution, but it is very expensive. V-carve does not have any available postprocessor for the AES machines currently, and horizontal drilling or machining will, unfortunately, never be an option for v-carve due to their specific software engine.
Zaheer Abbas
Forum Posts: 154
December 29, 2022 - 9:23 am
Hy dear
From where i can get the vcarve software?
And please let me know if possible to get directly from polyboard without using vcarve
Forum Posts: 2094
December 29, 2022 - 9:13 am
The files are very useful for comprehension,
I’ll come back to you when I’ve analysed it in more detail, but I think it will be necessary to switch from polyboard in DXF to Vcarve software to generate the Gcode
A bit slow during the holiday period
Zaheer Abbas
Forum Posts: 154
December 28, 2022 - 1:56 pm
Hello dear
Can u help me to get files for AES cnc ptp machine.
Machine can import:
Anc, txt or nc files
Check this link where u can find some files if it is helpfull
https://we.tl/t-4Q8UQccpQR?utm…..TRN_TDL_05
Most Users Ever Online: 704
Currently Online: Zaki Brijawi
Guest(s) 72
brendan kavanagh: 205
Conor Devoy: 158
Zaheer Abbas: 154
Patrick Maylor: 108
Tom Jackson: 106
Maciej Jaworski
Eleanor Maple
Filip Godu
Erik Rickert
Brandon Januarie
David Triller
Nathan Bruton
Michael Okyere
Timo Pitkänen
Topics: 2725
Members: 470
