Angled walls|Forum|WOOD DESIGNER
We would also like this to be added, we are doing more and more in rooms with angled walls in eaves etc. We have been using a cabinet to make it look like walls but it can get awkward to get them to be the right dimensions as you conrtol the dimenions externally not internally for these cabinets.
It is something the software should be able to do as you can do angled sides and tops of units.
Not directly but you can use a cabinet as a wall to do this easily,
Model in Q.D. Model folder
Cheers, Alexandre
OfflineHi all, hope you’re safe and well.
I have to make wardrobes to fit a room where the walls are at a 12 degree angle.
I have drawn my room with vertical walls at 90 degrees and I have drawn my cabinets with a 12 degree slope and that’s fine.
As I’ve been drawing I was wondering, is it possible to draw a room where the walls are not at 90 degrees to the floor?
Regards and thanks,
Conor
