Apply to the Surface Split from Sub-Method|Forum|WOOD DESIGNER
Forum Posts: 1444
October 30, 2024 - 9:45 am
I am not sure what the plans are at the moment. We will make an update announcement when it happens.
MITC
Forum Posts: 60
October 29, 2024 - 4:08 pm
Is it something that is going to be adding to future versions?
Forum Posts: 1444
October 29, 2024 - 4:05 pm
Currently the only way to apply rules to a surface split is in “fitting links list”.
MITC
Forum Posts: 60
October 29, 2024 - 2:09 pm
It will be something like this – I have removed all fittings apart from the ones I am talking about.
I have a double back that I have called “CrossBar” as a type. When ever a “CrossBar” is put in I am going to apply a structure based from the Materials sub-method that apples a surface split and has alternate materials as nil panels.
I then want to have screws only on the remaining panels. I can do this in the fittings link but have not found how to do it in the fittings sub-method.
Forum Posts: 1444
October 29, 2024 - 1:52 pm
It depends on the situation you are using it on. Do you have a cabinet file I can look at for you?
MITC
Forum Posts: 60
October 29, 2024 - 1:38 pm
Is it possible to get fittings to “Apply the Rule to the Surface Split” based on the Fittings Link Sub-Method? I cant see the check box anywhere but have a project that would be really useful if it was possible rather than editing it for each time I bring it in.
Guest(s) 37
everslyjoinery
Members: 537
