bar material when using double backs|Forum|WOOD DESIGNER
November 12, 2021 - 3:01 pm
You can’t use bars materials like Double-black
But’t you can use Assembly to achieved it
FF-ali-1.pngImage Enlarger
Please find file I upload available into QuickDesign models Folder,
You can copy/past side structure to other cabinet to have a clearest view, then change ‘Alignment position’
All the best, Alexandre
Laly
Forum Posts: 10
November 11, 2021 - 1:42 pm
Hi David,
Thank you for your message. As you have an active Premium Support membership, I have moved this topic to the technical section of our forum, so a member of our technical team can reply to you directly as soon as possible.
Thanks again for using the forum!laugh
Laly
November 11, 2021 - 12:13 pm
Hi
When I use double backs, after creating external zones, to put a face frame on my cabinet I would like to use a bar material instead of a panel material.  How do I do this?
Guest(s) 30
