Best way to produce angled shelving for shoes?|Forum|WOOD DESIGNER
Forum Posts: 1040
July 23, 2024 - 9:57 am
Hi Graham
Yes this is possible by applying the same rule to the cabineo on the shelf as the one on the regular drillings.  You can then also discard the 5 mm drilling hole for the cabineo as it will be replaced by the regular drilling hole.
In the case of angled shelves, it is also possible, but it will require some angle calculation as you can not dissociate front and back regular drillings. The only solution is to calculate the angle between the regular drilling holes when skipping 1 or 2 holes to angle the shelf. Also, the positioning rule for the cabineo needs to be adjusted according to the angle.
lock-to-drilling-angle.pngImage Enlarger
Graham MacRae
Forum Posts: 33
October 26, 2020
July 20, 2024 - 12:58 pm
Is it possible create full height regular drillings on the sides to match the fittings e.g. Cabineo X , so the shelves were adjustable?
Forum Posts: 697
July 17, 2024 - 9:23 am
Hi Scott,
Please see the following video. This shoes an example of adding shoe shelves with a lip on the front of the shelf. Fittings can be added to these shelves as normal. An additional central lip can be added using the same method as the front lip.
Let me know if you have any more questions.
scott powell
Forum Posts: 27
May 25, 2023
July 17, 2024 - 9:11 am
would like to be able to easily add angled shelves to a cabinet for shoes that can be spaced apart easy with each job and also a front lip and central lip for double depth shoes, complete with fitting like cabineos or shelf pins
Forum Posts: 1974
July 17, 2024 - 8:48 am
Can you provided overview of your needs,
But Free Divisions is still a good solution
scott powell
Forum Posts: 27
May 25, 2023
July 16, 2024 - 4:38 pm
hi, looking for the best way to produce angled shelving for shoes
thanks
Most Users Ever Online: 365
Guest(s) 36
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
EIlon Shperber
Alex Pop
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Topics: 2521
Members: 395
