Bifolding Door Hinge|Forum|WOOD DESIGNER
Tom Jackson
Forum Posts: 135
October 21, 2025 - 12:08 pm
Isaac,
Absolutely spot on, really appreciated the videos there really helpful – Cheers mate!
Speak in a bit.
Best,
Tom
Forum Posts: 1452
October 21, 2025 - 11:41 am
Hello Tom,
Also, see the compressed file attached this time. Import instructions are in the video.
Tom Jackson
Forum Posts: 135
October 21, 2025 - 11:12 am
Thanks so much for the video walkthrough – it’s been super helpful for learning! I noticed the file download link you sent isn’t working, as it leads to a broken webpage. Also, I realized I sent you the wrong file earlier sorry for that. I’ve attached the correct Murphey bed file (middle unit) this time.
I managed to add the 3mm diameter, 2mm depth drill pilot holes for the plates, positioned 24mm out from the center of the 35mm base in both directions. But I’m now stuck on attaching the fitting link itself. The first doors use standard Blum hinges, which I get (fitting link left and right of door system), but the second doors need this unique bi-folding fitting link. I’m confused about where the second door’s fitting link goes – does the system only have one fitting link (left or right), or is there a second one? If the left/right fitting link works with the normal hinges, where do I apply the one for the second doors?
Could you please handle the fitting link installation for us? I’ve tried but can’t get it right, and I’d really appreciate your expertise. Thanks again for your help!
Cheers,
Tom
Forum Posts: 1452
October 21, 2025 - 8:28 am
Hello Tom,
Also, see the xml hinge file attached. This is ready for import into PolyBoard.
Tom Jackson
Forum Posts: 135
October 20, 2025 - 4:14 pm
We are implementing a Murphey bed with bi-folding doors. The main door hinges have been set like normal, but we need bi-folding door hinges for the second panels of our Murphey bed design.
Here is a link to the bi-folding door hinge we need implemented:https://www.blum.org.uk/produc…..n=34391600
It has the technical data on the picture as well, if you could help us add the tooling data that would be a great help thank you!
Best,
Tom
Guest(s) 41
brendan kavanagh: 227
Emmanuel Sacco: 196
Carl O'Meara
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2906
Members: 540
