Bin Unit|Forum|WOOD DESIGNER
Bin Unit
May 2, 2023 - 3:23 pm
This is a special case!
If you have the Quick Design library,
Installing a classic drawer Tandem, height M without bottom
Then move distance from bottom and fitting for example 500mm
The first 509 in the zone moves the drawer display, the second 500 in the fixing link, says that the drawer does not start at 0mm from the bottom but at 500mm from the bottom
Oli Burdick
Forum Posts: 16
May 2, 2023 - 2:07 pm
Hi Alex,
Im trying to add a pullout bin to this unit attached. It runs on Blum’s tandembox antaro drawer system and i want to place it at a certain height from the top
,bottom, or fixed internal shelf perhaps…. but i am struggling to get it to work?!….i currently have the runners on the drawer front (door)!? im sure its a very easy fix!
many thanks!
Guest(s) 41
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
