Blind corner hinge application Blum|Forum|WOOD DESIGNER
October 20, 2023 - 9:48 am
Sorry, but you have no choice here. Split the frontage with a nil panel gives some trouble,
because nil components should be considered as windows and you can’t pass through it.
See this video on how to update, and fitting as XML files you can import into your libraries
Import.pngImage Enlarger
Please make a test before doing the final frontages
Blaž Jašovec
Forum Posts: 20
October 20, 2023 - 9:30 am
I need to put a hinge on the left side. Betwen the fixed back and the door.
October 20, 2023 - 9:18 am
Hi
Can you joined your cabinet?
Please find sample attached
Blaž Jašovec
Forum Posts: 20
October 20, 2023 - 8:48 am
Hello
I have a problem adding Blind corner hinge from blum to my cabinet.
How do you add this hinge to the cabinet?
link to he hinge in the blum catalogue
(EDIT: link no longer active)
Guest(s) 23
