Blum drawer Legrabox settings|Forum|WOOD DESIGNER
September 24, 2025 - 10:32 am
See this explained in your other post.
Ola svensson
Forum Posts: 100
September 24, 2025 - 7:38 am
Hi.
More Legrabox questions.
When I choose the Legrabox I would think you should be able to expect that the measurements of the bottom and back are correct and including the necessary groove to the drawer bottom,  but as you can see from the drawing and part list , its not correct and it doesn’t show the grove.
see the Blum fitting rules for Legrabox. Yes, we can adjust all this our self. But then, whats the point of a part library if its not set up correct? Then I think it would be better if you just told the users that you need to create all your fittings your self. Today they are there but you just cant trust them…
The Legrabox for us are not really a big problem since we are so familiar with it that I can spot from the part list right away that its not correct. but it diffidently creates zero trust in that I can assume that any of the other fittings you can choose would be correct without double checking it.
What are your thoughts about this?
Grateful for answers since this really starts to drive me nuts… we bought Polyboard in the light of that its initiative build up and design/part library would make the design and manufacturing process easy, and now here we are having to double check everything.
/ Ola
Guest(s) 27
