Blum Legrabox settings |Forum|WOOD DESIGNER
Forum Posts: 1591
September 24, 2025 - 10:31 am
Caroline,
I am sorry to hear that you are finding this difficult at the moment.
Please see the following video, I have tried to explain where your issues may be coming from:
Let me know if you have any further questions.
Forum Posts: 1591
September 24, 2025 - 8:19 am
I will look into this and respond to you soon.
Ola svensson
Forum Posts: 100
September 23, 2025 - 4:52 pm
Can you please advise on why the settings for the Legrabox that’s in the library on PB come in to the drawings preset with wooden sides and a counterfront?
Legrabox always have metal sides and click on front connectors. So why not put them in Polyboards library like that?
Can`t help to have a hard time understanding the point of putting parts in the library that’s not correct. We understand that we probably can make them right and adjust them our self, but then whats the point of the library?
When I chose that specific type of drawer I would like to have it right and not use time to double check that the settings are correct many times before I dare to start the cnc. Think it would make so much more sense if its correct to start with. and then you can change it if you need to for some reason.
I have chosen the Legrabox drawers, checked that only the bottom and back is there, but in the drawing/file in PB AND in the cutting-list it also included the sides and counter frontage – which is not a part of Legrabox,Legrabox always have metal sides and clip on fronts in wood. So there will never ever be a opportunity or choice to use a counter front on a legrabox drawer.
So now when I have done the vertical division in the CNC the frontage is recessed 10 mm from the front of the vertical division, which means the drilling is done in wrong position on the piece.
Guess there’s probably something we missed to adjust that leads to this result. But I have to admit that PB is stretching my patience to the limit.
Really looking forward to the really simple solution you probably have.
Caroline
Guest(s) 66
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
