Book case Design|Forum|WOOD DESIGNER
Book case Design
Forum Posts: 1959
May 29, 2024 - 4:47 pm
Please find your cabinetfile uploaded
Kind regards, Alex
Dov Bolel
Forum Posts: 8
May 19, 2024
May 29, 2024 - 1:54 pm
Pls can you send me the output files of the attached file
Forum Posts: 606
May 28, 2024 - 1:43 pm
Hi Dov,
Drawer-mods.pngImage Enlarger
If you access your drawers sub method, you can:
1. Create a new drawer method
2. Select the size drawers you want to edit
3. Edit the assembly of the drawers
Drawer-assembly.pngImage Enlarger
The next step is to edit your drawer assembly to suit your manufacturing. Under the priority order a ticked item will be created, an unticked item will not be created in your drawers.
Material-Styles.pngImage Enlarger
Next step is to select material styles.
Material-Styles-1.pngImage Enlarger
Then, apply the rules you would like for your materials. Here you can assign different panel materials in your manufacturing method for your drawer construction (the different materials you want to use for drawer components).
You can find further instructions on drawer creation through the following link:
https://wooddesigner.org/help-…..-hardware/
Let me know if you need further clarification on anything.
Dov Bolel
Forum Posts: 8
May 19, 2024
May 28, 2024 - 12:54 pm
Are you able to help me with the drawers as I want to make it out of 19mm sides and a 9mm bottom but I can only find premanufactured options
Dov Bolel
Forum Posts: 8
May 19, 2024
May 28, 2024 - 9:01 am
Hi, Thanks for those pointers, I was was panning on splitting the length of the fillers in my cutting software but I will probably now do it as you suggested, with regards to the side board I plan on adding real wood to the edge which is why its 20mm short, I have now realised I can do it via edging and make it 20mm thick but I’ll only change that on my next build.
Forum Posts: 606
May 27, 2024 - 8:14 am
Dov,
Not sure what you plan is here, I did notice your doors overhanging your side board.
Isaacimage-1.pngImage Enlarger
Forum Posts: 606
May 27, 2024 - 8:10 am
Hi Dov,
Depending on what you are going for, it all seems fine.
I’m not sure what your plans are for manufacturing the long panels such as fillers, side board and plinth. You are able to split the length with a surface split if this goes alongside your manufacturing process.
I can’t see any manufacturing methods/hardware links etc. on my end.
Hope this helps,
Dov Bolel
Forum Posts: 8
May 19, 2024
May 24, 2024 - 4:50 pm
sorry here it is
Forum Posts: 606
May 24, 2024 - 2:04 pm
Hi Dov,
Can you please upload a copy of the file you would like me to look at?
Dov Bolel
Forum Posts: 8
May 19, 2024
May 24, 2024 - 1:38 pm
Can someone look over this file and double check it there no major mistakes? Its my first time using this software.
Many thanks
Dov
Most Users Ever Online: 365
Guest(s) 24
brendan kavanagh: 165
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Tom Jackson: 83
Patrick Maylor: 81
Miryahya Khameneh
mathew moule
Christian Lopardo
Romerworld
Evaldas Gudenas
Petr Břichnáč
Ar Te
Ilie Mihail
GERARDO MARMOLEJO
Salman Bukhari
Topics: 2478
Members: 379
