July 16, 2018
Ok I just send you the new version via wetransfer
July 16, 2018
Hi ,
I have seen the same error and it seems the top part does not get imported in ON but ON is starting correctly. Do you confirm that the only the top is missing or also other parts ?
July 16, 2018
July 16, 2018
This bug has been fixed in the 7.07a beta version
I have sent you the upgrade file via Wetransfer
Your cabinet is sent to the development teams and let you know as soon as possible,
All the best, Alexandre
July 16, 2018
This bug has been taken into account and we will get back to you as soon as a correction is available.
Kerf Works
July 16, 2018
We are trying to use a long mortise and tennor for our filler panels. We have managed to do it on one project but on multiple others we are getting an issue there it is only putting in half of the joint. See the screenshots and attached file below. I assume this is a bug, could it please be looked at?
