Building a Frog Game - How to create slots in panels/divisions|Forum|WOOD DESIGNER
OfflineHi Manuel, here are your files. All the best, Stefan
OfflineHi Manuel, please order another CabinetFile so we can process all the files for you again with the required changes. Thanks, Stefan
Hi Stefan & Ness,
I’ve been going through the pdf docs & noticed that I didn’t center the top holes correctly:
I have now centered the holes to how they should be on the cabinet. Could you please reproduce/provide the dxf files, nested files, cutting lists, etc. from the attached revised project?
I made the changes in Polyboard Version 6.02c1
Thank you,
Manuel
OfflineHi Manuel, we don’t have any partners in Australia yet. Let us know how the search goes or if we can be of more help. We can always talk to whoever you find to see if they would like to partner with us. All the best, Stefan
Thank you for the quick response
I will call the CNC guy on Monday to discuss & get more details on what he means.
Do you have any partners/distributors in Australia using polyboard that can provide the CNC cutting services?
I’m surprised how there are only a handful of companies doing this CNC sort of work & each have specific requirements on how they want the panels laid out in the dxf files… Some want pieces separated by minimum 22mm, some can’t cut the angles due to size of cutters, some can’t have the pieces laid out like this as there’s no space to secure the plywood sheet down…etc. etc. list of limitations and non-standards just goes on & on
Hopefully I will find someone that can do this soon or I’ll just have to buy tools & learn to cut the wood myself
Cheers,
Manuel
