built in Drawer with applied door query|Forum|WOOD DESIGNER
Thomas O LOUGHLIN
Forum Posts: 22
March 22, 2023 - 11:11 pm
Thanks Alex, that makes sense now, cheers
Forum Posts: 2100
March 21, 2023 - 2:39 pm
See the video below with an example
There are two points to be aware of,
with built-in drawers you don’t need a front panel and you need to set it to nil panel,
but to add drawers to the PolyBoard drill run you need this front panel as a reference and if you set it to nil panel you need to be careful to deselect the “Ignore link if one panels is Nil” option
Hope that’s helpful, Alex
Thomas O LOUGHLIN
Forum Posts: 22
March 21, 2023 - 12:37 am
I’m currently doing a larder unit which will have ‘Hettich Avantech you’ pre assembled built in drawers and an applied door on the unit. so you open the door and pull out the drawers, but i’m having trouble doing this in polyboard ….. because the drawers are pre assembled I basically just need the runner holes drilled but cant seem to add Avantech you drawers and then add a door to the unit,
Any help would be much appreciated,
Cheers550500_avt_you_h187_web_1.jpgImage Enlarger
Guest(s) 65
brendan kavanagh: 209
Zaheer Abbas: 156
Patrick Maylor: 114
Tom Jackson: 113
Monica macias garcia
arno.s
JP123
Cristian mihoreanu
Jurij Avizen
H
magnus rehn
Stephanie Olaverry
Gustavo Muñoz
Topics: 2758
Members: 480
