built in drawers stepped past carcass 22mm|Forum|WOOD DESIGNER
Offlinehi, sorry i don’t think i explained myself correctly.
we are currently only using Polly board for carcass and doors we make frames by hand, the frames come over the carcass by the thickness of carcass so 18mm.
easiest way to explain i think would be, we would like the drawer fronts to be the size of the “built in” aplication but the drawer box to be in the position of “applied global” we know that this would mean the drawer front would be outside carcass, but then when we put our frame on carcass the drawer front will be flush with face of frame.
hope this makes sence
thanks
OfflineHi we do alot of in frame kitchens, inside frame flush with inside of carcass. we do drawer packs on them when we add built in drawers it sets the thickness of drawer front inside carcass where we would like them to still outside carcass, so on a 600mm carcass and 22mm door overall unit depth would be 622mm.
is this possible?
thanks
lee
