Cabinet File - Cutting List|Forum|WOOD DESIGNER
September 18, 2019 - 7:22 pm
Perfect, Thank you Alex
Forum Posts: 2110
September 18, 2019 - 7:04 pm
Hope that’s helpful
cheers , ALex
September 18, 2019 - 1:20 pm
Thank you Alex
I noticed that the Edging material detail is cut short in the cutting list therefor missing the full description. Is it possible to output in landscape so that the full details are visible? Or if possible in Excel?
Forum Posts: 2110
September 17, 2019 - 7:21 pm
Hi and sorry,
September 17, 2019 - 2:26 pm
Referring to the PDF Plans which seems to be excluded from the ZIP file.
September 17, 2019 - 2:12 pm
Hi Alex, Thank you for the reply
I cannot find the PDF build document attached. Seems only the cutting files are in the Zip file.
Note that i’m based in SA so not sure if there are suppliers that would use your Polyboard files. Please can you send me the full build document whereby i can then extract the dimensions of the various pieces.
Thank you
Lloyd
Forum Posts: 2110
September 17, 2019 - 12:41 pm
Attached here are your files,
Cheers, Alexandre
September 17, 2019 - 11:21 am
Thank you Carole.
I look forward to the response.
Carole
Forum Posts: 73
September 17, 2019 - 8:44 am
Hi Lloyd,
As you are a Premium subscriber, you have to use the Technical Support Forum so I’ve moved your post in the right place.
One of our professional will proceed your CabinetFile service request.
Carole
September 16, 2019 - 7:36 am
Hi Team
Been a while and ready for my next project,
Please can you assist with a cutting list for the attached project file.
Thank you
Currently Online: Stefan
Guest(s) 35
Emmanuel Sacco: 179
Zaheer Abbas: 174
Tom Jackson: 133
Beth Hinks
Manuel Belmar
Colin Rouse
Steven mason
Chas Joy
Eduardo Montilla
Mounib osman
Sebastian M.
Tom McGranaghan
Mohamed Mekayed
Topics: 2873
Members: 522
