Cabinet File Request|Forum|WOOD DESIGNER
January 7, 2016 - 10:34 am
Thank you very much and Happy New Year to you too.
Chris
January 7, 2016 - 10:22 am
Hi Chris,
Here are your files.
All the best for 2016,
  • sp_PlupMedia byrne-070116-01v01.zip(486 KB)
January 6, 2016 - 7:46 pm
Replacement Cabinet Files Request. Could you please output these?
Many thanks, Chris
Forum Posts: 956
January 6, 2016 - 3:39 pm
Hi Chris, there’s no way to delete posts at your end, but don’t worry, I’ve made a note about your allocation. Fine to send us another request. All the best, Stefan
January 6, 2016 - 3:20 pm
These are simple cabinets, so I’ve just calculated my own cutting list. All done now. No need to output them after all.
I’ll upload some other files to make use of my otherwise unused subscription!
Thanks, Chris
p.s. Is it possible to delete posts to this forum? I was trying to delete the request but couldn’t see a way to do so.
January 6, 2016 - 2:31 pm
Sorry – slight change – could you output the cutting list for these files instead please? Thanks.
January 6, 2016 - 2:26 pm
Could you please output the materials / cutting list for the attached cabinet files? Many thanks.
Chris
November 13, 2015 - 5:36 pm
Thanks very much Ness. I’ll take a look now and see if I can emulate what you’ve done in my own cab files.
Much appreciated.
Chris
November 13, 2015 - 6:52 am
Hi Chris,
You can set up the fixed panels as double backs at 0 from the front.
To get the correct width put a nil panel vertical division and then add the double back.
You can then make it over pass the top bottom and side. To aline it to the door with the correct slack use a negative overlap value.
I attach a model with the fixed panels. the doors are not sliding doors and probably not in the correct position to slide over on another, but they can be set up with the hardware drillings etc.
You can see that although the cabinet is set up as on piece, the middle vertical partition separates it into 2 units.
You could however be right in saying that it’s better to build 2 separate units, which might make it easier to align the overlapping doors.
sliding-02.jpgImage Enlarger
sliding-01.jpgImage Enlarger
November 12, 2015 - 7:49 pm
Thanks for your reply Ness. At this point there won’t be any Polyboard file to show as I can’t see how to make Polyboard reflect what I want to build, especially in terms of the fixed front panels. Unless I can add in those front panels and get an accurate cutting list etc out of PB, it won’t really help too much to have it in PB.
I don’t want to design a unit that is 2.4m wide as a single carcase – I’d never build it that way. The sliding doors in question on my last wardrobe spanned six carcases of 1m width each, with two 3m tracks. The only things that have to be aligned are the top, bottom and front of each carcase which has to be done anyway. The plinth and top filler just have to be set back approx. 100mm.
So, if I want PB to reflect real life rather than change real life to accommodate PB (!), can I get sliding doors to span different carcase cabinets? If not, I’ll just leave them out of PB. The main thing I want to do is get the fixed front panels in place.
Thanks, Chris
Guest(s) 26
Emmanuel Sacco: 206
Zaheer Abbas: 197
A S Brighton
Tobias Briander
Topics: 3027
Members: 594
