Cabinet File Request|Forum|WOOD DESIGNER
Hi Justin,
Here are your files in inches.
best regards,
Hello Justin,
Here are you manufacturing files.
Thank you. I am ready to build it! I am using this as a trial run to see if the program is something that I can use for furniture projects and cabinets in the future. So far I have been pleased. I want to see how the cut list and manufacturing documents go. I appreciate all your help.
Hi Justin,
You can select the sides and in the links you select the back . If you add an overlap your back will be more inside the cabinet .
The other workaround for the faceframes is selecting the back and in the links you take the sides. Set the type to groove and add until the back connects with the sides. I saw that if you add 46mm on each side it will groove in the back 5mm on each side.
There is no pocket hole assembly but there are special jigs for pocket hole assembly. Kreg is a known system for that.
Here is the file with drawer revisions and vertical separator revisions. When I applied face frames from the library it made the back panel come away from them. Not sure how to fix that. I followed your instructions and got the drawers and the separator fixed. This is a bathroom vanity that will have a live edge slab on top and a bowl that sits on top of it. I will also add feet to it which will raise it up off of the floor. The drawers not being full depth are to accommodate plumbing. I don’t want to do face frames for the back panel because it will be against the wall. How do I make the back panel fit and close in? Thanks. Also is there an assembly method that uses pocket holes?
