Hi Ed,
Good to know it all going well.
Good luck for the build.
March 21, 2015
Hello Iago,
Here are your files.
I've added a couple of fillers just to make the 3D look better.
Please check the DXFs are set up correctly for you.
Yes, I'll send you all the files.
It's late here so I'll try to send them tomorrow.
Iago Wynn-Jones
March 21, 2015
March 21, 2015
I have thanks Ness,
The units will have spacers between them, and this wider unit is designed to be overlapped by covering strips.
I'm sure I could have done a lot more with Polyboard in the design, but for now I'm just doing the basic cabinets.
I've included an image if it helps to explain… but thanks for checking Ness!
Hi Iago,
No problem to send the DXF files, but have you seen that the 2-2 false back cabinet doesn't fit into the space between the others?
