Cabinet for alcove |Forum|WOOD DESIGNER
OfflineHi again, Dean said he sent over some material and hardware options. Did you not receive that? He is sending again, please let me know how it goes. All the best, Stefan
OfflineHi Mauro, to get the cutting list and plans, you need to buy a CabinetFile, included with this is a review and revision of your design.
Click here for more info: https://wooddesigner.org/cabin…..e-service/
Click here to order: https://wooddesigner.org/membe…..discounts/
You don’t need this if you’re sending your design file to one of our suppliers. Please let me know if you’d like me to try to get a quote from our supplier as discussed by email.
Thanks, Stefan
OfflineHi Mauro, I’ll email you over the details of a supplier who will be able to help you.
If you’re planning on using a supplier, they would normally apply the hardware they use to your unit, so you don’t need to worry too much about this element of the project. They’ll be able to advise you how it works when you talk to them.
OfflineHi Mauro,
Your shelves look fine. You’ll now have to add the assembly details to know how the boards will be jointed together.
The type of assembly you use will depend on the tools and hardware you have available.
For the time being the back is not assembled to the carcase and you will need to either groove or rebate and pin it.
If you are painting, you can also just nail it onto the carcase but in this case you need to make it over passing.
Other boards can be assembled with hardware like dowels, screws or cams or assembled with grooves.
You have several Quick Design manufacturing methods that you can apply directly to your project.
For us to advise you, can you give a bit more information on your project and how your thinking of building it?
