Can't Change Materials on Door |Forum|WOOD DESIGNER
Tom Jackson
Forum Posts: 113
October 10, 2024 - 10:46 am
OMG…haha. Thank you Alex, that has resolved my issue!
Cheers,
Tom
Forum Posts: 2106
October 10, 2024 - 10:36 am
You can keep it, but you have to move it first.
Tom Jackson
Forum Posts: 113
October 10, 2024 - 9:18 am
Hi Alex,
Unfortunately I cannot put a hanging rail inside the unit without doing using this nil panel 0 from the front. It closes the zone. I also have to remove the ‘notch’ as it is a free shape object. This advice was given to me from Michel  when I was unable to apply the hanging rail as standard to this free shape cabinet. Any other advice to ensure both work would be great.
Cheers,
Tom
Forum Posts: 2106
October 9, 2024 - 3:18 pm
The Nil double back at 0 mm from front lock the depth, please set the position at 10mm for exemple before change thickness
DB.pngImage Enlarger
Tom Jackson
Forum Posts: 113
October 9, 2024 - 1:35 pm
hello,
I tried to change the door material and blanking panel to 22mm painted material, but it says something about ‘Panel structure generation failed’.
Not sure why, any help would be great thanks.
Cheers,
Tom
Guest(s) 140
brendan kavanagh: 212
Zaheer Abbas: 158
Tom Jackson: 113
Aurelian Draghici
Rory Parker
Harish Kiran Jetti
Gerard McDonagh
Livvy Kendrick
Esteban Raisiere
Monica macias garcia
arno.s
JP123
Topics: 2777
Members: 486
