Changing doors |Forum|WOOD DESIGNER
OfflineHello William,
Thank you for sending the file with the question.
In this situation, considering the doors were constructed with an inner tooling, they each need to be changed in the project mode. To speed this process up, I recommend using the “copy and paste” function, or by applying them through a structure.
William McCreanor
Forum Posts: 62
March 4, 2024
OfflineHello,
I have all my cabinets in a libary so i can just drop them into my project my problem now is i have a door with a stile and rails of 80mm allround but this job requires a 60mm rail allround which was requested after the 3D drawing was sent on is there a way i can quickly change them rather than going into each unit separately.
Thank you
Guest(s) 34
© Simple:Press —
