Changing Properties of Cover Panels|Forum|WOOD DESIGNER
Rooms Made Simple
Forum Posts: 73
September 1, 2022
May 20, 2024 - 2:50 pm
Thanks Michel.
Forum Posts: 1040
May 20, 2024 - 2:01 pm
Hi Dean,
There is no default preset possible for the panels called single panels in a project. Each time you create a panel, you have to indicate the edging and oversize. The only option is to create such panels, set the edge information, and oversize value. Save the project and use it as a template to start new projects. This way, you have a predefined set of single panels in your project. You might have to resize them according to the project if required.
Rooms Made Simple
Forum Posts: 73
September 1, 2022
May 19, 2024 - 6:24 pm
Hi folks,
  I want to change the default properties of added cover panels in Polyboard. I would like to set which edges need edging and set oversizing values.
Can anyone help?
Dean
Most Users Ever Online: 365
Guest(s) 25
brendan kavanagh: 165
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Tom Jackson: 83
Patrick Maylor: 81
Miryahya Khameneh
mathew moule
Christian Lopardo
Romerworld
Evaldas Gudenas
Petr Břichnáč
Ar Te
Ilie Mihail
GERARDO MARMOLEJO
Salman Bukhari
Topics: 2478
Members: 379
