CNC for Tooling|Forum|WOOD DESIGNER
CNC for Tooling
October 6, 2018 - 7:33 am
That works like inner tooling with axes reversed and surface is set up like drilling on edge
You or the developer team can call me when we need more information 😉
October 6, 2018 - 6:39 am
Hi Alex,
Thanks for this information.
Does the Polyboard Xilog file automatically set up the tooling face on the edge or do you have to set it manually once the Polyboard file loaded into Xilog?
October 5, 2018 - 7:35 am
Hi Grover and Ness,
With XilogPlus SCM, it’s simple you just need to have the tool set up to work with edge face
And don’t forget with edge 2 & 3 X becomes Z and edge 4 & 5 Y becomes Z
Groove-Xilo-2.pngImage Enlarger
Tool-Xilo.pngImage Enlarger
Cheer, Alex
October 5, 2018 - 5:37 am
Hi Grover,
Our developer team is ready to add edge grooving in the Homag and SCM post processor if they have the coding information. This can be added to next version of Polyboard.
best regards,
September 27, 2018 - 7:37 am
Hello Ness,
My boss also wants to ask how long can they do the code for homag/scm in case after collaborating. Do we need to wait for the next version of Polyboard?
Thanks,
Grover
September 27, 2018 - 2:20 am
Hello Ness,
Thank you Ness. My boss wanted to add Biesse as option 3. Would it be fine for Polyboard to edge grooving on this machine or it’s the same as SCM? What would you prefer among these three?
Thanks,
Grover
September 26, 2018 - 5:48 pm
Hi Grover,
You can write a macro in Xilog (SCM) or WoodWop (Homag) that you call from the Polyboard inner tooling functions.
The problem with this is that you can only call the macro as an inner tooling, and this only let’s you machine on the face of you part and not one the edge. Hardware will let you machine a groove on the edge but doesn’t let you call a Xilog or WoodWop macro.
So today we don’t have a solution to send the correct code to machine directly the edge groove from Polyboard to SCM or Homag machines. As I said before we are willing to add this code if SCM or Homag tell us the code that we need to add. They have already given us the codes for edge drilling but not edge grooving.
If you could explain your problem and ask them to contact us we could talk to them to see if we can create a solution for you.
September 25, 2018 - 4:34 am
Hello Ness,
Thanks for the reply. My boss said that he wants a screen to machine process. Is it possible to have this from Polyboard export to the machine directly using macro programming?
Macro.JPGImage Enlarger
Can we clarify if we can achieve this using a WoodWop/SCM/Xilog tooling file then import it to Polyboard?
Thanks,
Grover
September 24, 2018 - 6:08 pm
Hi Davo,
This hardware requires edge grooving which is currently only handled directly by Polyboard DXF output and Biesse CID or CIX post processors.
We would gladly add this function to to Homag/WoodWop and SCM/Xilog_plus output but we need to know the syntax of the PP instruction to be used.
So if you need to machine edge grooving directly from Polyboard you must ask Homag or SCM to send us the programming syntax and we will integrate this into our next version of Polyboard.
Otherwise both machines will machine edge grooves but you will have to manually add this in WoodWop (Homag) or Maestro (SCM)
September 24, 2018 - 2:16 am
Hello Ness/Stefan/Alex,
My boss wanted to ask which CNC would you prefer that is 100% working with Polyboard for tooling.
Homag/Weeke(Woodwop) or SCM/Morbidelli (Maestro/Xilog)? He’s deciding to purchase another CNC machining center for milling like the attached picture.
viber-image.jpgImage Enlarger
viber-image2.jpgImage Enlarger
Thanks,
Grover
Guest(s) 63
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
