CNC Reference point|Forum|WOOD DESIGNER
CNC Reference point
September 24, 2018 - 7:13 am
Hi grover,
Sorry, but we do not have any documents translated into English or French for Post-Pro Setup
September 22, 2018 - 2:37 am
Hello Alex,
We are currently using Vitap point k2 top and planning to have another type of machine that’ll suit our needs.
Anyway, can we ask for your English version on this one? (See attached)
Thanks,
Grover
September 20, 2018 - 6:54 am
Hi Grover,
I use SCM tech Z30 3axis, with multi-spindle drill.
In all CNC machines in wood applications, the precision must by near 0.1mm.
It’s why I give you this part, to do 10mm pre-milling to find where the problem is.
What kind of CNC are u using?
September 20, 2018 - 2:17 am
Hello Alex,
May I ask what kind of machine is that? Does it drill at precise coordinates?
Maybe our table saw causes the asymmetries?
Thanks,
Grover
September 18, 2018 - 9:18 am
Hi Grover,
In my opinion you will only move the real problem, and block for yourself even more possibilities.
The mirror function is only a temporary solution for a symmetrical cabinet, as soon as you do a slightly more complex cabinet it will not work anymore.
See example attached or the mirror function will then have no use although it remains very basic for the capabilities of the software.
I think it would be best to take a few hours to solve the problem.
P_20180918_085904.jpgImage Enlarger
P_20180918_090047.jpgImage Enlarger
P_20180918_090206.jpgImage Enlarger
P_20180918_091124.jpgImage Enlarger
September 18, 2018 - 6:21 am
Hello Alex,
We just found out that we have a mirror function on our machine. As we discovered, our side panels caused the main problem.
My boss wanted to ask if can we have a universal side panel instead of having 2(Left and right)?
 PP.JPGImage Enlarger
Though it’s possible if we just delete one, either “Left Side_3” or “Right Side_4” but is there any other way we can achieve 1 side panel file on Polyboard?
Thanks,
Grover
September 14, 2018 - 12:42 pm
Hi Grover,
Sorry we haven’t got a mirror function …
I don’t know how i can help you better…
for test CNC drilling I do 2 parts of this (see attached file TOP) in 19mm
you must have exactly the same distance into drilling between front and back or left and right…
and you should be able to assembly it in all directions
test.pngImage Enlarger
Maybe just one drilling axis has a bad position
Cheers , Alex
September 14, 2018 - 2:39 am
Good day Alex,
It seems that setting a reference point is important to us and the only way we can achieve this is through making inverted inputs.
Is there a way we can copy our cabinet in mirror? It’s quite difficult for us to rebuild a new cabinet in inverted view.cry
Grover
September 10, 2018 - 7:15 am
Hi grover,
This is used to return a non-symmetrical “Fittings-link”  see example attached
between link into left and right side with back.
link.pngImage Enlarger
All the best, Alexandre
September 10, 2018 - 2:53 am
Hello Alex,
Thanks for the reply. Yes, we did a 2mm pre-mill for this. 1mm on each side. Perhaps this is not enough?
May I also ask the main purpose of this? (See red square)
Fittings-Rule.JPGImage Enlarger
Thank you.
Grover
Guest(s) 21
